Can't Find Wardrobe?
This hasn't happened in a while. I installed Mos Invasion but can't find it in Smart Content or Content Manager. Even when I search for Mos Invasion. Even when I have nothing clicked in the scene. Even when when I use the search text box.
Now the product says it is compatible with Michael 3. I don't have that. I have Genesis, g2, and currently use M6…I would think Mos Invasion would be accessible and fixable to these figures. Any thoughts on where it is at?
I don't have this or I would tell you where it installs to, but, you should be able to find it under Products > M
failing that, it will be in the Content Library > Poser Formats > My DAZ 3D Library > Figures, it is a set of conforming clothing and props etc.
If you installed it using DIM, select the item in the Installed tab, right click, and then select 'Show Installed Files'
It also says this on the Product Page:
Thanks. I did find it in the Products>M…..rarely do I have to dip into there and it's very odd it shows up there but nowhere else.
And I did read that "first load Michael 3" but assumed that, like all other older clothing items I have, that this would load onto any figure. Typically I get that dialogue box asking what figure the item was originally intended for. That doesn't seem to be working here.
And just what is a JCM morph? (Really hate it when jargon is used instead of plain language.)
Don't know much about morphs either, but JCM is a Joint Controlled Morph, FBM Full Body Morph, ERC Enhanced Remote Control.
They do pop up every now and then, but you do become familiar with them given time :)
