fixing stomach bends for genesis 8 m?
I have a hard time using the Signs of Pregnancy morph if my character has to bend slightly. I often have to tilt the back an extreme amount to avoid an unsightly fold from appearing in the middle of the stomach and warping it.
Is there any way to fix this?
  • Lee MoonLee Moon Posts: 935
    edited August 2022
    I just tried doing a forward bend with G8M and the SoP morphs applied.
    If I bend the pelvis about 15 degrees, the hip -15 degrees (to counteract the pelvis bend), lower abdomen 10 degrees, upper abdomen 15 degrees, and the lower chest 20 degrees, I can get a good looking belly with the figure bent forward a fair amount.  That's with the SoP 8-9 months dialed in @ 50%.
    See if changing the values above will help reduce the skin folding.  I also have some skin folds and creases add-ons that look good for minor folds which go away when I turn those controllers to 0%.
    Hope that helps.
    Lee
    2202 x 2364 - 3M
    Post edited by Lee Moon on
