Is There an Easy Way to Convert Genesis skins to Genesis 2?
thrain9thrain9 Posts: 108
As the title asks, and by easy I mean a script or tool that is essentially a few mouse clicks?
If not, what is the correct way to convert skins from one generation to the next?
  • larsmidnattlarsmidnatt Posts: 4,511
    edited June 2015
    G2 already supports V5 uvs. So if it's a V5 skin you are OK.
    You can bake textures from one UV to another, its not super hard, but buying the shapes is way easier.
    edited as Mark128 had links :)
    Post edited by larsmidnatt on
  • mark128mark128 Posts: 1,033
    As I recall, most Genesis 1 skins used the V4/M4 or V5/M5 UVs. Genesis 2 F/M support the V5/M5 UVs by default. You can get V4 UVs for G2F with the Victoria 4 for G2F product and Slosh's UVs bundles for G2F and G2M:
    Victoria 4 for Genesis 2 Female
    Michael 4 for Genesis 2 Male
    Generation 5 UV Bundle for Genesis 2 Male(s)
    Generation 5 UV Bundle for Genesis 2 Female(s)
  • dizzy88dizzy88 Posts: 51
    Just to be specific about this, to apply V5 skins to G2F:
    1. Load a G2F
    2. Go to Surfaces and select the G2F figure
    3. Scroll down to the "UV Set" attribute and select "Victoria 5"
    See screenshot...
    375 x 646 - 65K
  • thrain9thrain9 Posts: 108
    Thanks, will check these links and info when i get home.
    appreciate the help
