Looking for Help with Iray OceanWorx
Fae3D
I just purchased Iray OceanWorx, and I'm having a bit of a hard time figuring it out. If you look at the promo images, you can see that there is distinct white foam in natural patterns on the water. However, no matter what settings I hit, I get either mostly blue water with little to no foam, or a sea of mostly blurry white foam. There is no instruction manual (not that I could find anyway). Is there a certain order you have to choose items, or a setting somewhere I'm missing? I thought maybe the tiling was off, but I can't find a way to adjust the tiling either. I'm sure this is user error, but I can't figure out what I'm doing wrong!
Here's what I would like to see (from the promos) promo other promo
Attached are 2 examples of what I keep getting.
Since I have this I thought I'd take a break from a narrative I'm working on and give it a try.
Turns out while I did have it, I hadn't installed it
At least we're starting out from the same place, more or less
I did get the same results you did, initially. Then the penny dropped and thought I may have the camera positioned too close. So I changed the focal length from 65 mm to 35 mm and moved the camera back. From the brief test that I did, it needs to be moved back manually via the scroll wheel; typing in a new value doesn't move the camera back but YMMV
That worked and was able to do this (quick and dirty render)
Getting back to the narrative now. Hth!
-Jaime
