UltraSceneryXT rendering in 3DL
drucdruc Posts: 499
Hi,
I recently purchased UltraScene XT. It said on the promo page "Daz Studio 3Delight Material Presets (.DUF)". I was a little surprised as UltraScernery is Iray only, although it will convert using https://www.daz3d.com/rssy-iray-to-3delight-converter-and-merchant-resource. ;
I have tried to render in 3DL and it doesn't work. My PC is 10 years old and takes too long to render in Iray. I tried a test of UltrasceneryXT with low instances of trees. 30 cycles took 2 hours 45 minutes. There was nothing else in the scene not even a sky dome. If I try to add anything else it can blow the render time (based on Ultrascenery) more than 2 and a half days. That was one pretty much default settings and one G8 character.
Is there a way to render in 3DL? There is nothing to convert as it renders from memory (or file location that is chosen when running the script.)
