Eyes! I Want to Soften the Whites
I'm looking for a step by step guide on how to soften the white of the eyes, and add a subtle pink/red gradient moreso around the edges. How do I get hold of the actual image to edit in photoshop for that part of the eyes?
Alternative:
I also want to try something similar inside of DAZ3D to soften the whites, much like how I edit the skin tone (color) and if so, what settings I need to tweak for the whites of the eyes?
At the moment my eyes are bloodshot, way more than I would go with Gen8 & 8.1 base char' lol.
And also, if someone could recommend eyes for Gen8 & 8.1, at the retail store that would suit what I'm looking for.
Thanks.
    If you zoom into your figure's head and click on one of the eyes. Then go to the Surface's tab and select [Figure Name]/Surfaces/Sclera you'll see the current image used under "Base Color". If you hover over the image it will tell you where the file is. You can open that file up in your favourite image editor and mess about with it as you like. Make sure to save the edited file somewhere else rather than overwriting the default. You can then swap out the current image with your edited image in any models that need it.
  • felisfelis Posts: 6,566
    edited August 2022
    If you select the character in the scene tab, and open the surface tab and exoand the list, you can find surfaces for Sclera. In that is a number of images, clcik one and you get an option for browse to that image. All the other images (for sclera) will be in the same folder.
    Post edited by felis on
  • GjSGjS Posts: 47
    Thanks SofaCitizen and Felis, greatly appreciate your help.
    The sclera is further down the list in surfaces, I adjusted the UI to see the fonts better and yeah, there is sclera.
    RESOLVED
