Compatability Question
bryanll1bryanll1 Posts: 141
How do you know if a clothing item will work with your models. For example, the "Hot Uniforms" line says genesis 2, some call out specific characters like "Victoria 4". Will these items work with Victoria 6 or other "6" series Genesis 2 models? How can you tell?
  • LeanaLeana Posts: 13,507
    This might help: http://www.daz3d.com/compatibility-matrix (it needs an update to add Genesis 3 and the latest Genesis 2 shapes)
    Basicaly, items made for V4 can be autofitted to Genesis 2 Female if you have the "V4 for G2F" product. after that they will work with the "6" figures.
  • bryanll1bryanll1 Posts: 141
    Is this what I need to convert the v4 clothing to fit v6?
    V4 Skins Auto Converter for Genesis 2 Female(s)
    Ok I installed it. Will it work automatically or do I have to do something to get it to work?
    With G2F selected in the Scene pane, when you try to load a piece of clothing made fro V4, then Autofit window will pop up, and ask you what figure the clothing was made for. Assuming that the clone has been installed correctly, V4 should appear in the list, select that, then the clothing type, and that should be it.
    Just came across this, it may help you more : http://www.daz3d.com/forums/discussion/58416/
