Importing content into Poser 10?
oneidakinsmanoneidakinsman Posts: 13
I recently picked up a copy of Poser 10. I have V4.2, including Morphs++ and lots of dynamic clothing as well. How do I import them into Poser? Most of the dynamics are OptiTex freebies with Poser support located in "My DAZ 3D Library". The main confusion is how to import the morphs. The others are in the runtime and the Install Manager. Thanks for any help you can provide!
  • frank0314frank0314 Posts: 15,102
    Add you library that is holding those files to Poser. You can set DIM up to install the files into your Poser runtime.
    555 x 512 - 58K
    553 x 518 - 101K
  • Richard HaseltineRichard Haseltine Posts: 111,408
    I don't think the DSON Importer will import dynamic clothing - in which case you would need to open the item in DAZ Studio and export as OBJ, then use the OBJ in the Poser Cloth Room.
    Morphs for what? If it's a figure loaded with the DSON Importer the morphs should load with the figure, as they do in DAZ Studio, as long as the folder you installed to iss et as a Poser external library.
    If the Optitex dynamic items are like this one http://www.daz3d.com/angelic-dynamic-gown-for-v4-poser-version then the Poser version will need to be installed into Poser as the Poser version is a prop which is then used in the cloth room.
