I cannot find the cell phone props that come with z-on-the-phone-pose-mega-set
All the icons in the library say pose, not any of them are props, does anyone else have this set and was able to locate the cell phones?
thanks
https://www.daz3d.com/z-on-the-phone-pose-mega-set
  • TogireTogire Posts: 458
    Have you tried to look in Props>Z on the phone?
  • felisfelis Posts: 6,566
    I would suggest to go to Content Library > Products > Z-on-phone-pose-mega-set
  • VicSVicS Posts: 1,273
    Yes I tried under props and content library
    The readme says it should be at:
    • “People:Genesis 8:Props:Z On the Phone”
    edited August 2022
    Thanks felis
    I did look there already, I will uninstall and reinstall through IM this time...
    still didnt show up, maybe if i restart it will show
    does anyone else have this set and have the phone props installed ok?
    Post edited by VicS on
  • butterflyfishbutterflyfish Posts: 1,814
    Yes, I have it, and that's where they are.
    If you still can't find it, I would suggest to look if it is at the expected file position with file explorer.
    And can you find the poses allright?
    edited August 2022
    VicS said:
    Thanks felis
    They are there for me. I mainly use Smart Content so this is where they show up in that.
    1930 x 978 - 2M
    Post edited by SofaCitizen on
    Thanks SofaCitizen!
    Im missing a few is there a way to make sure things are installed in sm art content you can let me know about it, it has been confusing for me.
    great pose set eh?!
    878 x 1424 - 751K
    If you have installed through DIM, DIM can tell which files it has installed, if you select the product and click on the triangle at right.
    I wonder if it is an installation problem or a Smart Content problem.
    Or the product was installed with DAZ Connect within DS to the 'Cloud' folder...
    VicS said:
    Thanks SofaCitizen!
    great pose set eh?!
    Hmm, well, I install everything using DIM and it has always seemed to add the Smart Content automatically. The important thing is to first make sure that the files are actually installed. The important one being "/Props/Z On the Phone/Z OTP Smartphone.duf" - have a look in the folder to make sure that is installed. The others are Wearables and so I think they would most likely depend on that one but if you want to check those they are in "/People/Genesis 8/Props/Z On the Phone" - there should be 8 duf/png pairs along with a "Hands" folder in there.
    However, I do have a second machine where I have to manually trigger a Smart Content update and so perhaps you could try that?  If you go to Smart Content tab and select "Content DB Maintenance" from the icon menu in the top-right. From the window that comes up check "Process Metadat Queue" and "Re-Import Metadata" and click Accept. This will check your Runtime/Support folders and list all the products. At this point I would suggest you uncheck everything and scroll down to see if "Z On the Phone" appears in the list. If it does you can check just that one and click accept which should force a re-import of all the Smart Content for that product.
    That is a bit of a guess tho since I would have thought that the install should have done that anyway.
    Thanks I did the Content DB Maintenance and checked only Z on the phone, what happened is now in smart content I have new tabs such as personal under props but the icons there are still the same 4 as before, the other ones like you have still missing
    edited August 2022
    If you go to Smart Content > Products and you there find "Z-on-phone-pose-mega-set" and dobble-click on it, it willl list all those kategories where there is content.
    How does that look?
    Post edited by felis on
