Is it possible to remove HD from morphs?
Richard John SRichard John S Posts: 391
Hi guys, I was wondering if it is possible to remove the HD shapes from morphs that don't have the option to turn it off? I assume not, but I figured I'd ask anyways. The reason why I want to turn it off is because of the drastic increase in rendering times.
  • AshcloudAshcloud Posts: 49
    I think the simple answer is no, which is a shame. The solution is also simple - do not buy any HD characters that do not have the option to add/remove HD details. Maybe, sooner or later, vendors will get the message.
  • fixmypcmikefixmypcmike Posts: 19,742
    It's not possible in 3delight, but in Iray you can control the amount of subD to use when rendering by surface, I believe.
    But if you are using Iray then you are not going to get a quick render. So, basically, do not buy HD characters (unless they have the option to add/remove HD details).
  • Richard John SRichard John S Posts: 391
    edited June 2015
    Thanks for the feedback guys. I found rendering HD characters to be faster in Iray than 3Delight. This was a test I did on a smaller portrait. I guess I'll have to look for an off option. I own a couple HD figures that have the off option. I wish the vendor for Adaline would update the product and add an off option. I was just excited to get the character and didn't bothere even checking if there was an off option... my bad there. However, I guess I will be staying away from HD characters for now on unless they have the off option.
    Post edited by Richard John S on
    Yep. Me too.
    I wish we could get a DAZ employee to confirm or deny that pretty much all of Genesis 3 Female's morphs are HD morphs.
  • Richard HaseltineRichard Haseltine Posts: 112,078
    Check the file list - HD morphs are .dhdm
    Thanks, the file list seems to indicate that only the mouth and some expression morphs are HD. I'll have to remember to start a new thread to detail the weirdness I am experiencing that made me suspect that there are a lot of hidden HD morphs in G3F.
