Decal Node Problems.
As soon as I load a decal node into my scene the Iray render preview changes to smooth shaded as if it's refreshing, but it doesn't refresh, it just stays grey. If I delete the decal node the Iray preview displays normally again.
Any ideas?
  • Is this true even with a very basic scene with just a low-polygon primitive?
  • mmoch25mmoch25 Posts: 145
    Yeah even with just a cube, like deleting it, if I just hide the the decal node the render comes back. I just updated the drivers and no change.
     I discovered the problem, the node was not parented to an object, As soon as it was parented the Iray render, renders.
    I don't know if this is normal, but at least it works now. If someone else could confirm it, that would be great.
  • barbultbarbult Posts: 27,499
    Yes, a decal node must always be parented to the object that you want the decal to appear on.
    Thanks.
