Eagle, Eagle Upgrade, Eagle Expansion Pack
NovicaNovica Posts: 23,925
I can use them in the backgrounds (not the most modern, up to date products- definitely not good for closeups!)
Do I need the Eagle to get the Eagle upgrade, and will the Expansion pack work on the Eagle Upgrade?
http://www.daz3d.com/eagle
http://www.daz3d.com/eagle-2-0-upgrade-from-eagle-1
http://www.daz3d.com/eagle-expansion-pack-1
  • scorpioscorpio Posts: 8,533
    If you are looking for a good Eagle you might want to take a look at Ken Gilliland's Birds of Prey packs over at Hivewire.
    edited June 2015
    Yes, yes and not sure, as I have both expansion packs this is the other one http://www.daz3d.com/eagle-2-expansion
    And Personally I think this eagle is far better than the other one mentioned and we see raptors flying over every day.
    Post edited by Chohole on
  • NovicaNovica Posts: 23,925
    I think I got all of Ken's stuff while he was here- not sure what it would be called though :) Was the eagle on this site when ken had the birds here?
    But the main thing is that expansion pack. Looks easy to use and a LOT of birds.
    edited June 2015
    No Ken was still working on those packs when he decamped.
    BTW, the eagle isn't really too bad in close up http://www.renderosity.com/mod/gallery/index.php?image_id=1219125&user_id=12932&np;&np;
    Done back in 2006
    Thanks Chohole- I'll get them all and see if the various birds from Expansion pack 1 will go onto the 2. I can always return the first one if it doesn't work. It won't be until later tonight but I will post what I find out. I do like the second eagle (expansion pack) better from the 2.0
    edited June 2015
    Ken's Eagles are new and personally I much prefer his versions especially as they are new the Daz eagle is rather long in the tooth.
    Ken has released quite a lot since leaving here Swans Ducks several Birds of Prey to name a few.
    He also improved his Owls, if you purchased them here you can contact him with proof of purchase and he will get you the updated versions.
    Just another thought the Daz eagle and expansion are old and probable predate DS mats so will be set up for older Poser version and might need the mats tweaking in some cases of older sets you even have to apply some of the textures by hand. Kens birds all have DS mats, even though they are accessed through the Poser directory.
    Post edited by scorpio on
    Hmm, I'll give that some thought- thanks so much!
  • fixmypcmikefixmypcmike Posts: 19,710
    Eagle 1 has been updated with a full DS version, Eagle 2 hasn't. Not sure about the expansions.
