Is there a shortcut or bottom that can zero out multiple morph slider at one time?
One can use ctrl or shrift to select multiple morph sliders at one time. I guess there must be a way to set the value of each of them at zero... Is there a shortcut or bottom that can zero out multiple morph slider at one time?
    Not sure if you can do that exactly, but you can go to the "Currently Used" section to see all the modifiers that are changed and Alt-Click each one to reset it.
    It would help if we knew, what you are trying to achieve. Talking about a shortcut makes me think, you are not talking about zeroing just some random morphs.
    This is what I meant. On the RHS you get a list of changed morph sliders and I want to change all of them to zero but it is tedious to set each of them to zero one by one.
    Ok, those are all expressions (poses)... All you need to do is right-click at the Parameters Tab and from the menu select Zero->Zero Selected Item(s) Pose and they will all be zeroed.
    If you select "Zero Figure Pose" instead, DS will zero all the pose-dials for the whole figure that are non-zero at that moment.
