Some pose presets suddenly stop working on G8.1F character
RenderPretenderRenderPretender Posts: 1,041
edited August 2022 in Daz Studio Discussion
Anyone have any suggestions as to why some pose presets suddenly fail to work? They were fine earlier, but have spontaneously stopped loading. All of the problematic poses involve a prop loading/parenting to a character. The prop loads, but the character remains in the base pose. The pose set was purchased commercially and I have contacted the vendor, but thought someone here might have a suggestion.
Thank you!
EDIT: NO pose from ANY set with a loading prop will work. Somehow, something seems to have happened to my character that is preventing such poses from loading. Only the accompanying prop will load.
Post edited by RenderPretender on
  • If they are loading a prop that sounds like a Wearables preset rather than a Pose preset - both can adjust the pose. Is the prop parenting correctly (I would assume it should parrent)?
  • RenderPretenderRenderPretender Posts: 1,041
    edited August 2022
     Yes, the prop parents, but the pose fails. This is a spontaneous/new development with this character. Basically, the character has stopped responding to wearables presets.
    What does your log say?
    edited August 2022
    It says it finished the asset load, but it doesn't load the pose, only the parented prop/wearable. I'm stumped.
    Is this a freebie or set from a store, or something of your own creation?
    Does the preset work on G8F character?
    edited August 2022
     It's a set from a store. The wearable preset works with the G8M in the scene, but NOT with a G8.1F or G8F. Also, a similar wearable preset from a different pose set fails as well. It seems that there's an issue with G8.1F or G8F assuming the actual pose, for whatever reason. It's VERY strange, especially since it worked fine in other scenes. Can something in a scene interfere with the loading of a wearable preset's actual pose? I don't know what else to try.
  • So I loaded a fresh G8F into a fresh scene. It worked then as expected. But the log says that a bunch of morph deltas also loaded following the loading of the asset (the actual wearable). But in the instances where the pose fails, those morph deltas never load, according to the log. But I don't know why.
  • NorthOf45NorthOf45 Posts: 5,896
    What is the Scene Identification of the figure in both cases?
    edited August 2022
     Genesis 8.1 Female. The Preferred Base is None, but she worked fine with these wearables and poses in another scene. Somehow she has apparently become corrupted and will not respond to poses with wearable presets. Really weird. And beyond frustrating.
