R/B/G Pixels - Final Render Issue
I'm unsure what to call this issue.
Red, Green, and Blue primary colored Pixels sometimes appear during and after a Render is finished in Nvidia Iray.
Sometimes this happens, and sometimes not. Most often then not, they do.
In the Attachment below is a small segmented area of a render that had this Pixel issue.
Is there something I can do or change like Render Settings, that will make these Pixels appear less or completely removed?
Any help is much appreciated.
361 x 221 - 81K
I am currently still looking for help on this issue.
That means the render has not rendered long enough.
The default limits for Max Samples and Max Time are quite low, I use 15000 for both.
What kind of computer do you have? (which GPU with how much VRAM and the amount of RAM)
Issue has been resolved.
Problem was: Daz did not update to version 4.20
Renders now finish with all noise filted out.
That wasnt the answer, but thank you for posting anyway!
