Daz3d shop is the server down? Anyone else having any problems with shop?
rampart_1576840087rampart_1576840087 Posts: 504
edited June 2015 in The Commons
I tried to view the shop couple hours ago ang just now.
on my status line I kept seeing ajax.googleapis.com and the page renders the start view, but that is it.
I suspect, browser queue is holding that page and the server is not working to update the page.
Just thought I would let someone know
Oh... and it took a VERY long time before the server put up the login entry page as well.
I didn't get a time out report page either.
The shop is not accessible, and hasn't been for several hours.
Just tried again... no workeee
Post edited by rampart_1576840087 on
  • rampart_1576840087rampart_1576840087 Posts: 504
    edited June 2015
    Still the shop isn't accessible to me.
    I am wondering... Is anyone else having any problems?
    It took over 2 minutes for the Login box to come up for the forums.
    I tried with Firefox and MSFT Explorer - same results.
    Haven't called my Internet provider yet, that is a possibility.
    I say that because there may be some issue logging into the ajax.googleapi.com with the provider.
    It would be nice to read if anyone else is having issues or not.
    Thanks.
  • Design Anvil - Razor42Design Anvil - Razor42 Posts: 1,250
    Seems fine from here.
    I just tried it on my iphone using my router WIFI using Safari browser and it seems to be working fine.
    I may be having a browser issue, but that almost seems remote.
    Since I tried MSFT Explorer and Firefox with same issues.
    Other sites appear to be working OK
  • WendyLuvsCatzWendyLuvsCatz Posts: 41,508
    It is an IP thingy that will fix itself eventually I had it happen on Facebook once.
    May take a day, something like cloudflare, I do not understand these things either but it has to clear itself up over a cycle after doing some stupid error.
  • BlueSiriusBlueSirius Posts: 86
    edited June 2015
    Sounds like DNS propagation - sometimes is just needs to work through..
    My only problem with the shop is using it when I get bored at work! My content Runtime expands as my bank balance does the shrinkie thing :/
    Some chick called Victoria 7 just blindsided me... this week, shes riffling through my wallet presently as I decided if I embrace her or ignore her for a while...
    Post edited by BlueSirius on
    I gave up last night and started again today.
    It takes about 3 minutes for the Login page to come up.
    I made a screen shot of what I see when I access the daz3d.com/shop page.(see attachment)
    The slide show at the top will not move, regardless of which arrow I use. I cannot use the login at top right corner and you can see the images render, but the text below the images doesn't render properly.
    I thought maybe Javascript so I checked.
    I still have that link showing in the bottom left corner status line... ajax.googleapis.com all the while I try to load anything associated with the store. I understand that is some kind of repository, which is supposed to be harmless.
    The shop is not workable, or accessible. I can click on an image and eventually the full content page renders, but the cart is not accessible.
    I will get with my IP provider today and see what can be done.
    Oh... this is the only site I am having this problem with. I can normallly use every site I normally go to, except Daz3d.
    The forums isn't bad after I get logged in, but it take up to 3 minutes for the login page to render so I can enter my login.
    1896 x 922 - 177K
    edited June 2015
    I was thinking something about my IP address as well. Nowadays, you are assgined an ip address at your IP provider and it stays with you until the provider changes it. The bit about DHCP is basically whoopla, because wtih a constant ON connection to the provider the IP address remains the same.
    I cannot change the IP address, because it as assigned from my IP account. In other words, it is set in stone until the IP provider changes it.
    When I see Google associated with just about anything .... I throw my hands up. Google is constantly pulling stunts. My IP address could be being blocked by Google for some reason. This may be a caveat that Daz3d did not think of when they set their store data on Google servers.
    The Fact is:
    1) I cannot buy anything, because the cart not accessible
    2) So this little problem is actually costing Daz3d money
    I haven't made a support ticket, but I probably should.
    I don't dare logoff these forums, because it takes so long to login again.
    The strange part is - I can access the WIFI from the same router as My desktop computer with my Iphone and it works as it should.
    I just don't like to transmit or make any purchases from my Iphone, because the whole world is listening.
    I submitted a support ticket and Daz3d support resolved the issue.
    I submitted to the bit about about the ajax.googleapis.com and the versions of the browsers I use.
    The shop started working about 30 minutes after I responded to their request for browser versions.
    I don't know what they did to fix it, but I suspect a host server side issue.
