Enhancement Face Power pose sheets, (Edit)
kitakoredaz
must need New power pose I believe. !!!
we may not use any controller for usuall expression,,, just use, head node map on power poze,,
then tweak each dot as you like,,
which can tarnslate (rotate, or scale) dot on map for new facial rigs.
and add some new cute button, (zero poze face, symmetly face,, and add for vismes icon,,etc)
(but hope it offered as FREE,,, please,,, it is just up-date,, NO??
daz may get more money with new figuers contents, iray or HD, then hope improve these tool,as free!!:coolcheese:)
and one more request,
about scene prop, or enviroment sets.
now we may not try triax weight map or add buldge ,,anymore,, will you?
(do not know, if buldge map still work with general weight,,though)
anyway I hope many scene or buliding offered as one set,,, with general weight free rigged part,
(about some door open, or some fllor to move easy in one set rigs, or translate each part as you like,,
to make MAZE,, then just zero figure, may retrun all !!)
without making many group or empty nodes!!
(oh,, if you feel ,it is good suggesiton, gread idea,,
I do not hesitate, if some vendor or daz hope to send gift card
or more powerful PC which I can use Iray,, if you hope %-P )
it seems better,
add another option,, to show these node as dot on 3d view face,, too.
add some button, change visible dot mode (with dot + wireframe, with dot + texture,, no dot etc)
and,,,,and,,,, may add button to " save current poze as facial poze preset.
on the power facial pose sheet.
add button to set key current poze on time line ,next frame,. (can adjust interval too
add button to set dot fou pupettier too,, (if someone need ^^;)
