Scene Question
bryanll1bryanll1 Posts: 141
Does anyone know if you can place people "in the water" when using the Tropical Bundle by Andrey Pestryokov?
  • Richard HaseltineRichard Haseltine Posts: 111,395
    You can always place people inside other objects - indeed, often avoiding it can be a pain. You may need to tweak the material settings, or use a water material setting from another product, for the best results - I can't recall how the water in the tropical scenes is set up.
  • bryanll1bryanll1 Posts: 141
    Ok thanks. I was just asking because the free beach scene has the water "in the wall" and not "on the ground", so you can't have people in the ocean.
    Yes, the beach scene is a "cyclorama" - essentially a backdrop prop with background, ground and a gentle curve between to avoid nasty shading. TheTtropicals sets, and most other environments, are actually modelled for the near elements though some environment sets sets will also use images for the more distant elements
