Question on Genesis 3 Female and 2
LorwinithLorwinith Posts: 60
Can I use Genesis 3 Female clothing and hair on Genesis 2 Female.
  • NadinoNadino Posts: 258
    If you're wanting to use Auto-Fit to convert the items from G3F to G2F out of the box, at the moment the answer is no.
    If you create your own G3F clone for G2F then the answer is yes. :)
  • The Blurst of TimesThe Blurst of Times Posts: 2,410
    Autofit is a tool. It's not necessarily the only path to take.
    You can also manually fit if you want to, especially with hairs. Clothing may behave in a way that you do not want it to after a manual fit.
    I've done it with V4 stuff that didn't fit how I wanted after the autofit script, anyway.
    Not easily...there's no G3F clone for G2F, so any real 'fitting' would either have to be done without a clone or in a modeler.
    I'm sorry, I thought the OP was wanting to do it the easy way.
    I agree with you The Blurst of Times, about alternatives. I sometimes use parenting, deformers or take the item into Blender to do it manually.
    The easy way is mostly what people want, but some of us can be quite stubborn when it comes to finding the hard way of doing things.
    Sometimes,I even intend to do it the hard way when I'm doing it the hard way.
    But, back to the OP, there's always a way even if it's not clear at first. These are 3d models, and the data does not care if it is Genesis 3 or Victoria 4. "Buggered to fit" still fits even if it's not the most elegant solution.
  • almahiedraalmahiedra Posts: 1,370
    edited June 2015
    There is a tutorial for Dawn clone for V4, that can be applied to other combination including genesis, it doesn't look complicated...but I don't know ...I haven't test it.
    edited: ahh, and Kattey tutorials?
    Post edited by almahiedra on
  • PendraiaPendraia Posts: 3,631
    edited: ahh, and Kattey tutorials?It's a good tutorial...I have used it a number of times. Some things have changed slightly in DS since it was written though...
