The leg length of the Genesis 8 Character
frownSo, I see the default leg length of the Genesis 8 character is awfully long, the female one specifically. How much should I shorten her legs to make them more anatomically accurate? I currently have it reduced to '-35.0%'
    ... to -35.0% ??? I think you have something amiss with your figures. Any character morphs with long legs at a non-zero setting perhaps?
  • murgatroyd314murgatroyd314 Posts: 1,569
    The rough rule of thumb (individuals, of course, vary a lot) is that the distance from ground to crotch is about half the person's height.
    I agree; I instead chose to override the limts of the Torso Length morph and set it to 175%, just to make it look normal. I found it grotesque otherwise.
    edited August 2022
    "-35%" looks ridiculous -- unless there is another length morph(s) at work somehow.
    1232 x 882 - 305K
    Post edited by Catherine3678ab on
  • MasterstrokeMasterstroke Posts: 2,497
    I am sure, lou618_2b45855fe7 meant to reduce the leg length about 35 %.
    "-35 from 100%"
    Setting the leg length at 65%
    I think he is right, the default leg length is already very long.
    "-35 from 100%"
    ;-) but they said "to" -35%. If it was to subtract only 35%, then the length is made "to" 65%. Which does make more sense if aiming for figures truer to the average RL figure.
    Many models do have long legs and other physical features not necessarily representing the masses.
  • cm152335cm152335 Posts: 421
    edited August 2022
    the right way to reduce legs length or any part of a character is with "SHAPING" tab
    slect your character / legs / - there is a "slider" for the "leg lengh"
    you can also use the scale option by slecting simultaneously the "thigh" and the "shin" togethers
    (keep pressed CTRL key and select thigh and shin) then X or Y scale
    Post edited by cm152335 on
