Iray Log?
Nyghtfall3DNyghtfall3D Posts: 815
edited June 2015 in The Commons
Does DS keep any kind of Iray log we can check to see how long a render took to complete when left cooking overnight?
I've got a lighting experiment rendering right now. I maxed the pixel samples and convergence, and want to know which condition it reached first if it finishes by the time I go to work later this morning.
Post edited by Nyghtfall3D on
  • BeeMKayBeeMKay Posts: 7,019
    You can use the regular log file for the information. It also tells you how many iterations were calculated on what device, etc.
  • Nyghtfall3DNyghtfall3D Posts: 815
    Where's the regular log file?
  • thd777thd777 Posts: 946
    Menu: Help -> Troubleshooting -> View Log File
    Ciao
    TD
    Easiest way is to access it from within Studio...
    Help > Troubleshooting > View Log File...
    The other is to hunt it down..
    In Windows, it should be in either
    C:\Users\\AppData\Roaming\DAZ 3D\Studio4\log.txt
    C:\users\\Application Data\DAZ 3D\Studio4\log.txt
    Not sure on a Mac...
    Well this is disconcerting.
    Iray reached the maximum number of pixel samples (15000), but the log doesn't say what percentage of the image was converged, and nothing happens when I click Resume.
    I've also just discovered that, unlike Lux, there's no way to adjust Filter or Tonemap settings once the render is complete. I had enabled Bloom during the render, and wanted to see what the image looks like without it. No dice. For an extra test, I tried adjusting the f/Stop, and nothing happened.
