upgraded to new 3090ti graphics card but Daz Studio still use CPU - how address?
DiomedeDiomede Posts: 15,466
edited July 2022 in Daz Studio Discussion
Greetings.
I upgraded from an old graphics card to a new EVGA GEForce RTX 3090ti and had the store install the card and the drivers.  Even when rendering a small scene (1 G8F, clothes, a prop bench, and a 4k HDRI), the renders are calculated by the CPU.  Obviously, something is up.  I am not tech savvy.  Is there an online checklist or something?
1165 x 672 - 147K
Post edited by Diomede on
  • DiomedeDiomede Posts: 15,466
    edited July 2022
    Greetings.
    I upgraded my old graphics card to a new EVGA GEForce RTX 3090ti.  However, even for small Daz Studio scenes, the renders are dropping to CPU, not GPU.  I verified with a very simple 1 G8F and clothes, 1 prop bench, and 1 4k hdri.  Still rendered entirely by CPU.  See attached screengrab of task manager.
    I am not tech savvy.  Is there an online checklist or similar to help me identify the problem?
    1165 x 672 - 147K
  • felisfelis Posts: 6,583
    If you in Daz Studio go to render settings > Advanced, is your graphic card then listed there?
    What driver version  is actually installed?
  • LeanaLeana Posts: 13,616
    Task manager default display doesn't display CUDA activity, which is what Iray uses. Check the log file in DS to see if the card was used.
    Thank you for the quick and informative response.  How do I check the log file?
  • SlimerJSpudSlimerJSpud Posts: 1,456
    Download GPU-z. It's a simple, standalone program that tells you everything about the activity on the graphics card. Start GPU-z, select the "sensors" tab, then start your render. You should see GPU Usage go to 100%.
    https://www.techpowerup.com/gpuz/
    Here is some information from the help / video card and log files, but I don't know how to interpret it.  Does this mean that the render was done with the graphics card?  Or not?  What should I be looking for?
    394 x 296 - 26K
    1078 x 928 - 341K
    1037 x 945 - 370K
    1055 x 382 - 140K
    1656 x 457 - 255K
    1548 x 792 - 480K
    1164 x 631 - 362K
    It says that it is using yoir 3090ti for rendering.
    For another time, attach the log as a text-file.
    Thanks.  And will do next time.
  • kwerkxkwerkx Posts: 105
    Agree with @felis, looks like the GPU rendered the scene.
    Also, in the task manager you had up, click the "Performance" tab, then click "GPU0" or similar name on the left panel.  That will show you your GPU memory use.  Apart from an install error (your logs show Daz recognizes the card), the only reason for a CPU render is if you run out of VRAM.  In that case, GPU memory use spikes near max around the start of the render, then drop significantly as the CPU takes over.  Alternately, the logs will clearly indicate that it's a CPU render.  Hope this helps and have a great day.
  • Richard HaseltineRichard Haseltine Posts: 111,816
    Merged threads.
  • nicsttnicstt Posts: 11,715
    Download GPUz
  • if the gpu isn't rendering ... and you don't have a program like battlecoder shirase on daz... you'll know immediatly it's all on the cpu ... because unless it's been fixed the cpu render engine will use every bit of cpu cycles, running up to 100% gets a little difficult to do anything including stopping the cpu render
