Environment Background
When a background is inserted in the background enviroment can it be adjusted such as scale transform x y z? Cheers
  • Richard HaseltineRichard Haseltine Posts: 112,089
    It can be rotated in ninety degree steps and mirrored, but not scaled or translated.
  • define background.
    however, while now I tend to render a front scene with the dome hidden and saving the render as a tif then using pshop to put background behind
    way back then I used one set of my renders as a background I just put put in on a cube as a surface and then sized the cube as needed.
    in the first picture the back row is all either on cubes or just building fronts but either way I could raise or lower them or scale them etc.
    The second picture was rendered with just the bus station and then suprise a render of those same buildings were layered in behind but I can still do scaling etc on the layer
    1188 x 593 - 532K
    1417 x 863 - 1M
