Urban Sprawl - can't delete skydome (ungroup?)
HorusRaHorusRa Posts: 1,665
edited March 2019 in New Users
Post edited by HorusRa on
    Is this the one you have : http://www.daz3d.com/urban-sprawl
    According to the Product Page :
    Presented as a figure(.cr2), Urban Sprawl's body groups are as follows: •Northside
    •Southside
    •WestSide
    •Eastside
    •Central(contains all of the roads)
    •SkyDome
    •Roadmarkings
    Does SkyDome not appear in the Scene pane, if so, click the little eye icon next to it, and that will make it invisible. I don't have this set, so I can't check.
  • HorusRaHorusRa Posts: 1,665
    edited March 2019
  • Richard HaseltineRichard Haseltine Posts: 111,345
    Yes, hiding a bone works for Iray as for 3Delight.
    I think it should do, you could give it a try?
    Iray also has a Dome, so you may need to go into Render Settings > Environment, and change it to Scene Only, or try some of the other options. I am not too well up on Iray at the minute, but there are loads of threads on how it all works.
    edited March 2019
    edited March 2019
  • ShawnBoothShawnBooth Posts: 465
    Hiding it is fine. Nothing to worry about.
    edited March 2019
    horus3523 said:
    Wait, are we saying that hiding a sky-dome WILL allow IRay lighting to work? And if yes, what about using an hdri in any given scene where that's the case?
    Hiding, using the 'eye' in the Scene tab, yes. Hiding by turning Opacity down/making transparent/visible in render 'off'/all those other tricks that work in 3DL...no.
    Using the 'eye' tells DS not to pass the item on to the renderer, so, in essence, it isn't there.
