Creature creator HD. . .
cclesuecclesue Posts: 420
I can't get the gol-darn thing to work.
On a Mac latest everything
daz studio 4.8
I have loaded CC and CC hd along with Zaniya hd (which I think I should see as Smart Content but do not) to this address:
Users>shared>My DAZ 3d Library>Etc.
Should I be directing it somewhere else for 4.8
if so how do I do that.
I'm so confused!
Speaking of Confused I can't get the Dang DIM to work either.
  • Richard HaseltineRichard Haseltine Posts: 110,578
    If you are installing with DIM the target path would be Users>shared>My DAZ 3d Library. If you are isntalling manually then the contents of the Content folder in the zip should be merged into Users>shared>My DAZ 3d Library.
  • cclesuecclesue Posts: 420
    edited June 2015
    which as you can see from above post is exactly where I installed them. It isn't hard to follow the installation process once I get to the shared>My DAZ 3d Library. I just can't see them in studio
    Post edited by cclesue on
  • LindseyLindsey Posts: 2,015
    Check the product page description for your Creature Creator products. Most of those products contains only new shapes for Genesis, Genesis 2 Female or Genesis 2 Male, there are no user-facing files in the Content Library nor Smart Content.
    You can access the morphs in either the Parameter and/or Shaping tabs and mix them up if you like. You can create your own shaping presets for ease of use in your Content Library if you desire them.
    What are "user-facing files"
  • BeeMKayBeeMKay Posts: 7,019
    Basically, the icons you see in the content library or smart content.
