Saved Morph Assets Load On Default, Help!
ben_roprimben_roprim Posts: 46
I dont know what to call this problem.
Upon even loading a regular zero/default Genesis 8 figure, saved Morph Assets I made from Zbrush are loading at 100%.
I used the File > Save As > Morph Assets
Then I used, Paramiters > Memorize > Figure/Shape
Now these morphs load with every single default, saved character, so on.
How do I stop this from happening?
In the Attachments Below is a Visual Screenshot of the issue at hand.
Any help is much, much appreciated. As I cannot figure this out.
1302 x 855 - 278K
Post edited by ben_roprim on
  • barbultbarbult Posts: 27,473
    Nudity is not allowed. Show your character in smooth shaded draw style or remove the textures. Moderators will likely remove your attached image. As to your problem, did you save the morph assets while they were dialed to 100%? You should dial them to 0 before saving.
  • ben_roprimben_roprim Posts: 46
    Yes, I saved them while at 100%.
    Should I "resave" them at 0%? I'm unsure how to go about this, without further damaging the current problem.
    edited July 2022
    Yes resave them at 0% ... to the exact same folders as the previous save went. You want the new to overwrite the old files.
    {I don't recall ever memorizing anything when saving my morphs}
    Post edited by Catherine3678ab on
     It worked!
    However, there was an extra step needed, as the first time it didnt not work.
    Here was my process to make the fix happen you suggested:
    First - Turn the conflicting Saved Morphs to 0% on the default Genesis.
    Second - Use the Right Click/Parameters > Memorize > Memorize Figure, Pose, & Shape
    Third - Do Save As > Morph Assets > (Your Morphs) > Finish
    Without the Memorize, the problem persists. When Memorized before saving, it has fixed the issue.
    Thanks for you time to help solve this problem, kudos to you!
    You probably shouldn't have memorized in the first place. That is not a normal step in morph creation and saving.
    With the existance of up-to-date tutorials explaining certain functions of Daz Studio quite deminished, along with the existance of expensive Paywalled Tutorials, experimentation and self testing is all we have left for the poor common user like myself.
