Stability issues of the "Face Transfer" function and updates/tips
tayloranderson2047tayloranderson2047 Posts: 116
edited July 2022 in Daz Studio Discussion
I found the Face Transfer function in Daz Studio could be very unstable under some circumstances:
1. Some standard photos (even standard ID photos like Visa Photos with white background) could fail to transfer  (crash/error)
2. Same photo could be transferable at one time but fail to transfer at another time
Does anyone encounter the same issue as me? How do I contact the author about the issues? ()
I don't see the updates for this product (or is it updated with Daz Studio?)... How would you guys use the Face Transfer pluggin? Do you pre-process the photo before use?
It might be inappropriate to post any real person photos here for illustration, but I guess thoes who use Face Transfer a lot know what I am saying,,,
Post edited by tayloranderson2047 on
    It helps to remember that it is a plugin. The face image used does not need to be 4k or 8k for example.
  • It helps to remember that it is a plugin. The face image used does not need to be 4k or 8k for example.
    I thought the plugin only removes the water mark and the limit of transfers... So the core of this function is not a built-in?
    Purchasing the plugin removes the water mark and the limit on transfers, yes. But it is still a plugin. Many plugins will choke or something if one uses a huge image for them to make calculations from. If you use a smaller image, it is easier for the plugin to make its calculations. The size of the photograph does not affect the size of the texture image applied to the figure.  {don't make it too small though, you'll want the new face texture to be decent enough to work with in the image editor when you're fixing it up.}
