Change the "duplicate formulas" message please?
How can I disable that message? It seems like a permanent fixture in my case as I cant seem to fix the issue, but every time I open a file, I have to press "ok" first. I can actually live with the issue as it has not affected my work ever, it's the message that is the problem as I cannot set up bulk overnight renders because of it, and it's not like it has an option to choose from either (yes or no).... It's just ok" button.
Is it not possible to put this message somewhere else, please?
  • Richard HaseltineRichard Haseltine Posts: 112,059
    Turning off the message, if you could, would not solve the issue - your figuers are probably taking a lot longer to load as a result of it. Help>Troubleshooting>View Log File and search for Duplicate, that will usually tell you which files are triggering the issue - most likely it is two different characters using the same name, so you should identify which the other one is, report both to support or the artist, and for now remove one (or edit the names in the file to remove the duplication, but be aware that that may clash with any official fix)
