What is the base resolution for the new Victoria 7?
vintorixvintorix Posts: 220
I am unable to find any technical details about V7
All info is helpful
  • Cris PalominoCris Palomino Posts: 12,945
    What do you mean? Where do you set base resolution or what is the actual polygon count?
    The base count is 17K polys.
  • prixatprixat Posts: 1,627
    Hi Vintorix,
    The free base G3f will show up in your DIM anytime now, if you can't wait for that (or if you don't use the DIM) you can get it now by going to your account and downloading it from there.
  • vintorixvintorix Posts: 220
    17K polys, ok
    That was I wanted to know!
    Thanks
  • edited December 1969
    prixat,
    Free base G3F?
    Got it!
    Thanks
    (Some days I am not so alert as I used to be)
    Thank you prixat,
    I am installing it now.
  • alexhcowleyalexhcowley Posts: 2,408
    Cris,
    How does this compare with G1 and G2F?
    Thanks,
    Alex.
    edited June 2015
    Cris,
    Thanks,
    Alex.
    It's less than G1 and quite a lot less than G2F
    Genesis 1:
    19296 vertices, 18872 polygons, 26 material groups, 73 bones (including root)
    Genesis 2:
    21556 vertices, 21098 polygons, 28 material groups, 81 bones
    Genesis 3:
    17418 vertices, 17000 polygons, 17 material groups, 173 bones
    Post edited by Chohole on
