Iray render slower than 3Delight
yagakisan
Hi,
I' ve read about faster rendering with Iray, but with a simple scene without any lights I see that Iray is much slower than 3Delight.
I render animations and every frame with 3delight takes let's say 10-15 seconds where with Iray it takes not less than minutes.
I have a Nvidia 970 GTX.
Are there other settings to enable this claimed speed?
I' ve already tried to use Iray shader without success.
A Titan X graphic card (or better, several of them), for example, accellerates rendering times by quite a bit. :-P
But seriously, if your scene is bigger than your VRam (which usually is the case if you have two characters in it - like, my card has 2GB Vram, but still isn't used very often, because it can't hold the scene), your render is falling back to CPU.
CPU can be accelerated a bit by Optix-activation, and if the scene is properly lit by a good HDRI (shut off the headlamp of your cameras!) it will shave off a bit. I've heard that rendering bigger images instead of smaller images will improve render times as well, but I can't confirm that.
I rendered a very simple animation using a single G2male walking around, and that took me 45secs per frame, by cutting it off at 250 iterations. Another one using 3 robot characters in it and an actual scene came out at 80 secs per frame.
EDIT:
Just for the record, this is what DAZ oddicially has to say about a good Iray system:
https://helpdaz.zendesk.com/entries/67520170-System-Recommendations-for-DAZ-Studio-4-
Iray requires actual lighting in the scene. Without lights it will be very slow.
Please see this thread here - http://www.daz3d.com/forums/discussion/56788/
Try adding a full GI lighting solution to your 3DL scenes...and see how long it takes then.
Almost no one has those and I don't expect many people to be getting one any time soon. Even PA's who do hundreds of test renders a day at times are fine with something like a 970. I have yet to exceed my 4gb of vram. Even when rendering a large stonemason scenes with 2 fully dressed figures didn't go over my vram.
Iray is not necessarily faster than 3dl most of the time. It really isn't expected to be. Speed is very much driven by how you set up the scene just as it is in 3DL. Lighting plays a part and an under lit scene will render slower than a well lit one. Having the surfaces converted to Iray helps as well because there will be less to calculate.
