IRAY IN 4.20 NOT WORKING WITH RTX 3080 12GB (SOLVED)
aldiegavnaldiegavn Posts: 0
Rendering does not work whatsoever even with the simplest object such as a lonely volleyball.
I have a i5-11600k, 32GB of RAM and a RTX3080 12GB. I have CPU fallback disabled and the GPU only enabled. I have the newest driver on it, 516.59 Studio Driver.
Here's what pops up on the log.
2022-07-18 23:39:03.228 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: optixInit() failed: Entry symbol not found. Please update your NVIDIA driver (www.nvidia.com) to at least 471.41.
2022-07-18 23:39:03.228 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3080) is no longer available for rendering.
2022-07-18 23:39:03.229 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3080) is no longer available for rendering.
2022-07-18 23:39:03.229 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : All available GPUs failed.
2022-07-18 23:39:03.229 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : No devices activated. Enabling CPU fallback.
2022-07-18 23:39:03.229 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3080): Device initialization failed, will not be used
2022-07-18 23:39:03.230 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering with 0 device(s):
2022-07-18 23:39:03.230 Iray [INFO] - IRAY:RENDER ::   1.0   IRAY   rend info : Rendering...
2022-07-18 23:39:03.230 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: No worker to render with: aborting render
I've reinstalled DAZ, the drivers, everything, I don't know what to do anymore. Can't render in the scene to see it in real time nor can I render it to be saved as a picture, just a black photo.
EDIT:
GUYS YOU WON'T BELIEVE THE SOLUTION LMAO. I followed this advice:
So I had posted on the nVidia forums and an employee reached out to me:
The solution was to search the Windows directory for nvoptix.dll and/or
nvrtum64.dll and if I found anything outside a
Windows\System32\DriverStore folder to delete them. Sure enough I found
copies of both files under both Windows\System32 and
Windows\System32\DriverStore so I moved the ones from System32 and that
solved my issue. I hope this ends up helping somebody with the
same issue, this had me running around for quite a while to where I
thought I needed to get a better GPU.
Post edited by aldiegavn on
  • felisfelis Posts: 6,534
    What driver are you using?
    The log says to update your driver.
    Where did you get the drivers, here?, https://www.nvidia.com/Download/index.aspx
    Minimum driver version is 471.41, if you are now using 516.59, try some older ones. "The latest" drivers are not guaranteed to be the best working ones.
  • aldiegavnaldiegavn Posts: 0
    As I said in the post, 516.59!
    Yes I only get it from Nvidia directly, I guess I'll try some older ones... cuz for 3080 I'm at 5xx drivers!
    Downgraded to 512, still nothing........
    410 x 305 - 16K
  • tam_c3df5332fctam_c3df5332fc Posts: 147
    edited April 2023
    Hey @aldiegavn,
    Did you ever find a solution to this issue?
    Post edited by tam_c3df5332fc on
  • Richard HaseltineRichard Haseltine Posts: 111,516
    tam_c3df5332fc said:
    Hey @aldiegavn,
    In which version of DS? The minimum driver version often changes when Iray is updated.
