How can I tell what product a morph comes from?
barbultbarbult Posts: 27,499
When I select a morph from the shaping tab or the Parameters tab, how can I figure out what product the morph came from?
    Manually [i.e. not through the program] in the data folder for the main figure, under morphs, ask the computer search function [at least one can on W7] to find the exact name or part thereof file, then right-click browse to the containing folder. It should be there in a subfolder with either the creator's name or the product's name.
  • barbultbarbult Posts: 27,499
    Well manually is better than nothing! Thanks. I will see if I can figure out the product that way. It seems like DAZ Studio should have a way of showing that info.
    Well it's possible IF done by the creator of the morphs BUT for some reason(s) the majority decided not to.
    I put my little morphs into a subfolder under morphs so I can find them.
    I tried your search technique, and it worked for the morph I was looking for. Thanks again.
    You're welcome, glad it worked :-)
