Unlimited loading of Iray
The iray is not working. I can't do both viewport and render.
GPU share is 0%... I can only see white and white objects in Viewport.
my computer:
rtx3060ti 8G /16G ram /AMD 5600x
Help me. plz
2034 x 1325 - 898K
  • Richard HaseltineRichard Haseltine Posts: 111,315
    Does using Texture Shaded Drastyle enable you to render?
  • cksdn4212cksdn4212 Posts: 0
    Yes, texture shaders are available And my dazs can use filaments(PBR). Only Iray is not available.
    When it was first installed, the iriay was available. But it was broken after days : Graphic Drivers and Daz are also the latest versions
  • aldiegavnaldiegavn Posts: 0
    I also have this issue, newest driver 516.59, i5-11600k 32GB of RAM and a RTX 3080 12GB....
    2022-07-19 00:57:19.829 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: optixInit() failed: Entry symbol not found. Please update your NVIDIA driver (www.nvidia.com) to at least 471.41.
    2022-07-19 00:57:19.830 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : CUDA device 0 (NVIDIA GeForce RTX 3080) is no longer available for rendering.
    2022-07-19 00:57:19.830 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [WARNING] - IRAY:RENDER ::   1.0   IRAY   rend warn : All available GPUs failed.
    2022-07-19 00:57:19.830 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: Fallback to CPU not allowed.
    2022-07-19 00:57:19.830 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER ::   1.0   IRAY   rend error: CUDA device 0 (NVIDIA GeForce RTX 3080): Device initialization failed, will not be used
