Saving each frame of a scene to separate save files.
I found that DAZ can only render the first frame of the series using the GPU, the rest are rendered using the CPU. I do not like it. But I did not find any solution on the Internet. Only if you restart DAZ after each frame, or save each frame of the scene to a separate file and then use batch rendering. But saving each frame is long, dreary and sad. Well, really no one has come up with a utility that makes this process automatic? Like batch render, just batch save.
