Why are some clothes invisible in Poser
LaandanLaandan Posts: 62
I have bought some clothes, for example the !Aeron clothes, and they work fine in DAZ3d and I used the DSON converter, but they are invisible in Poser. Is there a way to make them show up in Poser? Some of the clothes, half of them work and the other half are invisible.
  • QuietrobQuietrob Posts: 361
    edited June 2015
    The Clothing you have don't have Poser Companion Files. They are needed for materials to work properly in Poser. You'll need to create them.
    Btw. Did you try exporting the clothing as a CR2?
    Post edited by Quietrob on
  • Richard HaseltineRichard Haseltine Posts: 111,363
    If you have created PoserCFs of your own and are getting nothing at all it is possible that the assets files (the ones in the Data folder) are not being found - for those and for the textures in the Runtime folder you need to have the folder you installed to set as an external Runtime in Poser (click the folder with a plus icon in the top-right corner of the Poser library panel). If that is correct already then it may be that their set-up is not compatible with Poser.
  • pwiecekpwiecek Posts: 1,598
    If the clothing has a transparency map, try setting the transparency to .999999 rather than 1.
