Syntax error loading Marcoor Control Room Aged
Hi, I'm hoping someone can help me out here. I purchansed SS Marcoor Control Room and Marcoor Control Room Aged during the summer sale, but getting issues with the material set on the addon. The Materials folder shows the Iray Materials with an error and the logs show that there is a Syntax error - expected '{' or '[' when trying to load the asset. I've uninstalled and installed multiple times and still it does not work. I know others must be using it correctly however since I see it used in the Gallery (1).
I'm wondering if this is an install issue, but not sure how to solve it. I install all my items directly from DS (while logged in). I attached a screenshot of my UI.
Logs show:
2022-07-15 17:56:45.848 [INFO] :: Beginning Install of "SS Marcoor Control Room"
2022-07-15 17:57:33.515 [INFO] :: "SS Marcoor Control Room": Install Succeeded.
2022-07-15 17:58:45.479 [INFO] :: Prepare asset load (open): /Environments/Architecture/SS Marcoor/Control Room/Scene/Iray/Control Room !Pre.duf
2022-07-15 17:58:45.479 [INFO] :: Locking viewport redraw...
2022-07-15 17:58:45.479 [INFO] :: Viewport redraw locked.
2022-07-15 17:58:45.593 [INFO] :: Native format content directories: 3
2022-07-15 17:58:45.594 [INFO] :: Poser format content directories: 3
2022-07-15 17:58:45.594 [INFO] :: Other import format content directories: 0
2022-07-15 17:58:45.594 [INFO] :: Begin asset load (open): /Environments/Architecture/SS Marcoor/Control Room/Scene/Iray/Control Room !Pre.duf
2022-07-15 17:58:45.882 [INFO] :: *** Scene Cleared ***
2022-07-15 17:58:45.883 [INFO] :: Determining missing assets...
2022-07-15 17:58:46.719 [INFO] :: Setting textures...
2022-07-15 17:58:46.850 [INFO] :: Scanning for addons...
2022-07-15 17:58:46.863 [INFO] :: Cache update required: /data/Ravnheart/Marcoor Control Room/sci_fi_control_desk.cache.dsf
2022-07-15 17:58:46.864 [INFO] :: Cache update started: /data/Ravnheart/Marcoor Control Room/sci_fi_control_desk.cache.dsf
2022-07-15 17:58:46.864 [INFO] :: Cache update finished: /data/Ravnheart/Marcoor Control Room/sci_fi_control_desk.cache.dsf
2022-07-15 17:58:46.869 [INFO] :: Cache update required: /data/Ravnheart/Marcoor Control Room/sci_fi_control_chair.cache.dsf
2022-07-15 17:58:46.870 [INFO] :: Cache update started: /data/Ravnheart/Marcoor Control Room/sci_fi_control_chair.cache.dsf
2022-07-15 17:58:46.871 [INFO] :: Cache update finished: /data/Ravnheart/Marcoor Control Room/sci_fi_control_chair.cache.dsf
2022-07-15 17:58:46.886 [INFO] :: Creating node geometry...
2022-07-15 17:58:46.957 [INFO] :: Creating UV sets...
2022-07-15 17:58:46.957 [INFO] :: Creating materials...
2022-07-15 17:58:48.461 [INFO] :: Resolving legacy figures...
2022-07-15 17:58:48.461 [INFO] :: Preparing modifiers...
2022-07-15 17:58:48.461 [INFO] :: Creating modifiers...
2022-07-15 17:58:48.469 [INFO] :: Creating sum stage formulas...
2022-07-15 17:58:48.471 [INFO] :: Creating multiply stage formulas...
2022-07-15 17:58:48.471 [INFO] :: Finalizing modifiers...
2022-07-15 17:58:48.471 [INFO] :: Finalizing channels...
2022-07-15 17:58:48.471 [INFO] :: Finalizing materials...
2022-07-15 17:58:48.471 [INFO] :: Sorting property groups...
2022-07-15 17:58:48.472 [INFO] :: Setting up follow targets...
2022-07-15 17:58:48.473 [INFO] :: Finished asset load (open): 0m 2.879s - /Environments/Architecture/SS Marcoor/Control Room/Scene/Iray/Control Room !Pre.duf
2022-07-15 17:58:48.831 [INFO] :: Unlocking viewport redraw...
2022-07-15 17:58:48.831 [INFO] :: Viewport redraw unlocked.
2022-07-15 17:58:49.260 [INFO] :: Loaded image: holo_projector_2_tx.jpg
2022-07-15 17:58:49.337 [INFO] :: Loaded image: holo_projector_1_tx.jpg
2022-07-15 17:58:49.487 [INFO] :: Loaded image: sci_fi_room_1_tx.jpg
2022-07-15 17:58:49.662 [INFO] :: Loaded image: sci_fi_room_2_tx.jpg
2022-07-15 17:58:49.765 [INFO] :: Loaded image: control_desk_4_tx.jpg
2022-07-15 17:58:49.829 [INFO] :: Loaded image: control_desk_6_displays.jpg
2022-07-15 17:58:49.906 [INFO] :: Loaded image: control_desk_6_tx.jpg
2022-07-15 17:58:49.920 [INFO] :: Loaded image: control_desk_1.jpg
2022-07-15 17:58:49.976 [INFO] :: Loaded image: control_desk_7_displays.jpg
2022-07-15 17:58:49.999 [INFO] :: Loaded image: control_desk_2.jpg
2022-07-15 17:58:50.073 [INFO] :: Loaded image: control_desk_7_tx.jpg
2022-07-15 17:58:50.101 [INFO] :: Loaded image: control_desk_5_tx.jpg
2022-07-15 17:58:50.122 [INFO] :: Loaded image: control_desk_3.jpg
2022-07-15 17:58:50.221 [INFO] :: Loaded image: chair_1_tx.jpg
2022-07-15 17:58:50.307 [INFO] :: Loaded image: chair_4_tx.jpg
2022-07-15 17:58:50.383 [INFO] :: Loaded image: chair_4b_tx.jpg
2022-07-15 17:58:50.455 [INFO] :: Loaded image: chair_5_tx.jpg
2022-07-15 17:58:50.529 [INFO] :: Loaded image: chair_2_tx.jpg
2022-07-15 17:58:50.609 [INFO] :: Loaded image: chair_4c_tx.jpg
2022-07-15 17:58:50.684 [INFO] :: Loaded image: chair_3_tx.jpg
2022-07-15 17:58:50.774 [INFO] :: Loaded image: wall_mounts_1_tx.jpg
2022-07-15 17:58:50.868 [INFO] :: Loaded image: wall_mounts_2_tx.jpg
2022-07-15 17:58:59.616 [INFO] :: Beginning Install of "Marcoor Control Room Aged"
2022-07-15 17:59:21.376 [INFO] :: "Marcoor Control Room Aged": Install Succeeded.
2022-07-15 18:00:42.060 [INFO] :: Prepare asset load (merge): /Environments/Architecture/SS Marcoor/Control Room/Materials/Iray/Aged/Sci Fi Room Walls.duf
2022-07-15 18:00:42.060 [INFO] :: Locking viewport redraw...
2022-07-15 18:00:42.060 [INFO] :: Viewport redraw locked.
2022-07-15 18:00:42.210 [INFO] :: Native format content directories: 3
2022-07-15 18:00:42.210 [INFO] :: Poser format content directories: 3
2022-07-15 18:00:42.211 [INFO] :: Other import format content directories: 0
2022-07-15 18:00:42.211 [INFO] :: Begin asset load (merge): /Environments/Architecture/SS Marcoor/Control Room/Materials/Iray/Aged/Sci Fi Room Walls.duf
2022-07-15 18:00:42.211 [INFO] :: C:/Users/<my name>/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_24421/environments/architecture/ss marcoor/control room/materials/iray/aged/sci fi room walls.duf (1,1): Syntax error - expected '{' or '['
2022-07-15 18:00:42.211 [INFO] :: Error loading asset: C:/Users/<my name>/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_24421/environments/architecture/ss marcoor/control room/materials/iray/aged/sci fi room walls.duf
2022-07-15 18:00:42.211 [INFO] :: Operation failed
2022-07-15 18:00:42.335 [INFO] :: Unlocking viewport redraw...
2022-07-15 18:00:42.335 [INFO] :: Viewport redraw unlocked.
2022-07-15 18:01:42.011 [INFO] :: Prepare asset load (merge): /Environments/Architecture/SS Marcoor/Control Room/Materials/Iray/Aged/Sci Fi Room Walls.duf
2022-07-15 18:01:42.011 [INFO] :: Locking viewport redraw...
2022-07-15 18:01:42.011 [INFO] :: Viewport redraw locked.
2022-07-15 18:01:42.141 [INFO] :: Native format content directories: 3
2022-07-15 18:01:42.141 [INFO] :: Poser format content directories: 3
2022-07-15 18:01:42.141 [INFO] :: Other import format content directories: 0
2022-07-15 18:01:42.141 [INFO] :: Begin asset load (merge): /Environments/Architecture/SS Marcoor/Control Room/Materials/Iray/Aged/Sci Fi Room Walls.duf
2022-07-15 18:01:42.141 [INFO] :: C:/Users/<my name>/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_24421/environments/architecture/ss marcoor/control room/materials/iray/aged/sci fi room walls.duf (1,1): Syntax error - expected '{' or '['
2022-07-15 18:01:42.142 [INFO] :: Error loading asset: C:/Users/<my name>/Documents/DAZ 3D/Studio/My Daz Connect Library/data/cloud/1_24421/environments/architecture/ss marcoor/control room/materials/iray/aged/sci fi room walls.duf
2022-07-15 18:01:42.142 [INFO] :: Operation failed
2022-07-15 18:01:42.273 [INFO] :: Unlocking viewport redraw...
2022-07-15 18:01:42.273 [INFO] :: Viewport redraw unlocked.
3835 x 2098 - 6M
  • NorthOf45NorthOf45 Posts: 5,895
    edited July 2022
    The "Syntax error - expected '{' or '[' " is typical of faulty decryption or download using Connect. Try deleting the Product and download a fresh version.
    Post edited by NorthOf45 on
  • ShimrianShimrian Posts: 590
    How do I delete and download a fresh version? I'm using Smart Content tab in Daz. I clicked uninstall and reinstall and that didn't work. I also opened file location and deleted the entire folder that it was in and tried to reinstall it after that, but it still shows the same error.
    Not sure, actually. I don't use Connect. cheeky
