Morph Loader Pro - my custom preset is not shown
Eternal ForceEternal Force Posts: 307
edited July 2022 in Daz Studio Discussion
Hello guys,
It is supposed to be very simple but obviously I am doing something wrong here. I open Morph Loader Pro. I click "Choose Morph Files" and load my OBJ file. I change some setting (e.g. Reverse Deformation). Then I click the button "Save Preset".So far so good. My new preset is saved. When I expand the menu "From" at the top, I can see my freshly saved preset there. BUT... when I try to open the menu "Preset" in the middle of  the picture, I cannot do it. The only option I see is "None". So I have to change manually the options like Reverse Deformationon on each opened OBJ file. Again and again and again. What am doing wrong? Can you help?
721 x 1103 - 225K
Post edited by Eternal Force on
  • Richard HaseltineRichard Haseltine Posts: 111,677
    Different presets, I think - the one you are using is the oen that also appears in the OBJ import and export dialogues, setting scale and axis options. Click the preset name (currently Custom) next to From: to access the list.
  • felisfelis Posts: 6,547
  • Eternal ForceEternal Force Posts: 307
    edited July 2022
    Are there two presets or just one? I thought it was just one preset but it is supposed to be loaded in two different fields. The first field for preset allows me to control the scale of import. However, I cannot load my preset into the field in the middle.
    I even tried to use the button "Save Project" in order to have a second preset for Reverse Deformation. Nope. When I click "Load Project/Object", I just load a saved OBJ.
    I am looking for a way to have preset for Reverse Deformation. I can access the list on top but I cannot load my preset in the field in the middle. Please have a look at the picture.
    706 x 1093 - 292K
    As the video shows, you need to right-click on the morph with the options you wish to make a preset.
    Thank you so much, Richard. It turned out to be so simple and I couldn't figure it out on my own cheeky   Now I know it! yes
