Problems loading Ironman13's Private Party
BeeMKay
I bought this set yesterday, and when loading the ready to render set, I get the error message below about a missing IBL file (see below).
Is there any fix to this? (It's a Party Pooper, kind of :-P)
510 x 874 - 61K
Post edited by BeeMKay on
Have you checked in DIM to see if that file was installed. In the Installed tab, right click, and show installed files for Private Party, select 'Show Installed Files' and that will tell you if it is there, and where it was installed to.
It looks like you have a folder called 'runtimes' on your Desktop which appears to be your version of My DAZ 3D Library, is that where it was installed to? Or if that is the vendor's name and folder location, you will need to tell support about it, as the paths to the IBL are obviously wrong, and need to be changed?
Sorry if you know all of this already, but it does look like a very weird path to an image file :)
Based on multiple past experiences of this type of message, I can assure it's the builder's fault not the installers fault. If you use the script editor on the file you are trying to load, then that path will be present. Just find the correct location (using DIM if you did install by that method, or manual search), edit and save the script.
She saved it with an absolute, not relative path...and since you aren't Stephanie...and are not using her desktop, you won't find it...
You should submit a ticket for this, as it really does need to be fixed at the PA/DAZ level.
