a fun lekku project
Alright I find i am needing some help I've been trying to setup lekku for gen and perhaps gen2 I'm trying to use the existing products (The Medolian) to create it but I am finding I'm running into an issue and i'm not sure how to fix it if i fix two of the head tails to gen i cannot move them around to make lekku but if i fix them to a null object or any other object then fix it to gen or gen2 if i pose anything it they move to all sorts of odd poses. Does anyone have any suggestions and if the original dev for (The Medolian) has a fix i'm more than happy to buy it as an add on pack.
Huzza i figured it out using the Medolian. Attached a null object and target null to head then attached the head tails it and just moved things around. Now the head dress lol.
Note that the extra head part is a geograft — it replaces the back of the head of a Genesis figure, so you can only add one. The problems you were having were because the "tentacle" is built to be a geograft, it's supposed to be attached to a Genesis, so the object "centre point" is in the same place, on the ground between her feet. Something to keep in mind if you do this sort of thing again.
