Problems with the texture of the eyes.
nsamatixnsamatix Posts: 3
edited July 2022 in Daz Studio Discussion
Hello!
There was a problem using textures from Genesis 3 female on genesis 8 female.
When applying eye textures from Aiko 7, for example, a fringing appears, which is visible when rendering.
Is there any way to fix this?
On the first screen, the default genesis 8 female, everything is fine with the eyes.
On the second screen, the texture from Aiko 7 and the edging immediately appeared.
630 x 563 - 173K
977 x 526 - 295K
  • felisfelis Posts: 6,574
    Please allow for automatic line-break. You are breaking the format.
    Aiko 7 has her own UV layout. I assume there is a slight difference to how G8F UV layout is, and therefore a mismatch in the texture.
  • nsamatixnsamatix Posts: 3
    edited July 2022
    I am using this product. But it doesn't help with the eyes.
    It seems that this problem cannot be solved.
    https://www.daz3d.com/genesis-3-character-uvs-for-genesis-8-female
    And how to enable line break?)
    If you are using that product, can't you then go to the eye surfaces and select Aiko 7 UV under UV set?
    For formatting, how are you inserting your text? It looks like inserted as code.
  • Richard HaseltineRichard Haseltine Posts: 111,790
    Change Paragraph Format to Normal, instead fo Formatted, and the lines will wrap to fit - and not use the typewiter font.
    edited July 2022
    I did it. For all parts of the eye in the Surface section, I selected the Aiko 7 mesh. This does nothing.
    630 x 563 - 173K
    977 x 526 - 295K
    Post edited by nsamatix on
    Then I am out of ideas.
