Converting G3 to G8 Anatomy / Attachments [Solved]
dustinmeyer1234dustinmeyer1234 Posts: 134
edited July 2022 in The Commons
I been converting the base characters from g3 to g8 using scripts from riversoft but I have the https://www.daz3d.com/cthulhiana-hd I was able to convert the main body but no go on the head set it comes with. when I attach it to g8f the auto fiter comes up and and select g3f it attaches right but none of the morphs work along with when I pose the g8f it breaks. is there a way to convert these to g8 and still have the controls from g3.
725 x 752 - 423K
Post edited by dustinmeyer1234 on
    If the head is a separate figure, use "Scene Identification" to make it G8 (Edit->Figure->Scene Identification)
    which part do I say for g8 by default when I auto fit it put g8f as one of the option I tried also putting the other option to g8f but it still messes up
    Preferred Base should be Genesis 8 Female.
    Load the original Genesis 3 headdress into the scene without having the G8F selected, select the headdress and change the "Scene identification" from G3F to G8F and fit the headdress to your G8F - Should not bring the autofitting dialog up.
    that worked thank you
    1172 x 842 - 783K
