Victoria 8.1 Face Skin
Hello again,
Is there a way to reduce the acne on Victoria 8.1? I would like to have a "cleaner" face skin
Thank you
  • TogireTogire Posts: 458
    You can use on any char any other skin of the same family. Just pick a g8.1F skin that you like and apply it on Victoria.
    Alternatively, you can photoshop the skin to change the parts that you don't like.
  • Hello, do you know where can I find other skins? I only have Victoria 8.1 with HD and morphs installed
    In People>genesis 8 female>materials>base materials, there are 4 skins for G8.1F.
    Maybe you can find some free chars with a skin, but most free chars contain generally only the shape and not the skin.
    But the best way is to purchase new G8.1F chars. They almost always come wth a skin. Any G8.1F char can do, and you can frequently find some of them heavily discounted.
    Note that you can also use the skin of a G8F or G3F char, but it is slightly more complex.
  • markusmaternmarkusmatern Posts: 615
    When you are working with Victoria 8.1 you should at least have access to the four available skin materials from the Starter Essentials:
    When working with Content Library you can navigate to People/Genesis 8 Female/Materials/Base Materials/Iray you should find:
    1. Genesis 8.1 Female Base MAT All Maps A
    2. Genesis 8.1 Female Base MAT All Maps B
    3. Genesis 8.1 Female Base MAT All Maps C
    4. Genesis 8.1 Female Base MAT All Maps D
    When working with Smart Content you should find them in Materials/Iray/Feminine/Genesis 8.1 Female/Skin
    When you are talking about acne do you mean the visible pores? You could also try to reduce the normal strength settings in the Surfaces pane for the face.
  • Hello, thanks all for your reply. I have to install the starter kit, that's probably why I wasn't finding any extra skin. With acne I was meaning the freckless. I hope to extend my collection if Daz will do some good deals for the prime day.Would be great to have an extended starter kit with more hairs,clothes,props and poses
  • nicsttnicstt Posts: 11,715
    edited July 2022
    You can also use G8 on Victoria 8.1
    ... Hell, you can use G3, because they are the same texture-wise.
    Just put the Torso in the Head and Body slots.
    Post edited by nicstt on
  • leonardo_3285321dleonardo_3285321d Posts: 99
    edited July 2022
    Hello all,
    I found the additional maps after installing the starter kit, but unluckily they are not HD.
    With acne I mean the red points, see attached image. I tried to change the normal map value, but is not doing a lot in my case.
    Thanks
    1920 x 947 - 427K
    Post edited by leonardo_3285321d on
  • zombietaggerungzombietaggerung Posts: 3,953
    Those are Freckles.....
