Daz not using GPU - cancelling render causes memory de-allocation issue
2022-07-06 20:56:42.904 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: CUDA device 0 (NVIDIA GeForce GTX 1070): an illegal memory access was encountered (while initializing memory buffer)
2022-07-06 20:56:42.904 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: All workers failed: aborting render
2022-07-06 20:56:42.904 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: CUDA device 0 (NVIDIA GeForce GTX 1070): an illegal memory access was encountered (while de-allocating memory)
2022-07-06 20:56:42.905 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.9 IRAY rend error: CUDA device 0 (NVIDIA GeForce GTX 1070): an illegal memory access was encountered (while de-allocating memory)
2022-07-06 20:56:42.905 [ERROR] Iray :: Internal rendering error.
2022-07-06 20:56:43.166 [INFO] :: Saved image: C:\Users\david\AppData\Roaming\DAZ 3D\Studio4\temp\render\r.png
2022-07-06 20:56:43.172 [INFO] :: Finished Rendering
2022-07-06 20:56:43.200 [INFO] :: Total Rendering Time: 7.60 seconds
2022-07-06 20:57:20.025 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : Device statistics:
2022-07-06 20:57:20.026 Iray [INFO] - IRAY:RENDER :: 1.0 IRAY rend info : CUDA device 0 (NVIDIA GeForce GTX 1070): 3 iterations, 2.559s init, 1.654s render
2022-07-06 20:57:20.026 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.0 IRAY rend error: CUDA device 0 (NVIDIA GeForce GTX 1070): an illegal memory access was encountered (while de-allocating memory)
2022-07-06 20:57:20.027 [WARNING] :: ..\..\..\..\..\src\pluginsource\DzIrayRender\dzneuraymgr.cpp(367): Iray [ERROR] - IRAY:RENDER :: 1.0 IRAY rend error: CUDA device 0 (NVIDIA GeForce GTX 1070): an illegal memory access was encountered (while de-allocating memory)
if i restart daz the gpu is available again for one render.
What else do you have running/open at the same time?
Do you under/overclock your GPU?
i do have an overclock running, but im sure i disabled it to test.
other than that i have gpu-z and hwinfo64 open to troubleshoot cpu/gpu rendering and vram usage.
let me try it again without msi afterburner in memory at all
yep, if i turn off msi and any overclocks it works.
