My character turns into slender man when scene is reloaded
I have never had this happen before. I have a G8F with dforce hair and dforce outfit that I ran dforce on and posed in a small scene.The character poses and looks correct until I save it and reload the scene at a later time. The most noticeable problem is that the arms all the way down to the fingers are stretched out like a slender man and are often behind her back in an unnatural way. I have some t-pose poses, and when I use one the character goes back to regular t-pose and "seems" fixed. If I use other poses that weird deformed freak returns and the arms are in the wrong pose.
I have discovered that if I 0 my custom-made character morph that was imported from blender, the character returns to normal. I have used this morph a lot for at least 6 months.
Is this a known issue? What can I do to fix it?
What happens if you use "Adjust Rigging to Shape" on the deformed figure?
I will have to try that. At the moment, it is fixed. I don't know how. I removed the dforce outfit that I thought might be causing the problem and added another g8f to the scene saved and reloaded. Now the character is fine...
I guess I will need to reproduce the problem and try Adjust Rigging to Shape
Yes that fixes it. Why does this work? What can I do to avoid this situation?
Edit: I think this might fix it. https://www.daz3d.com/forums/discussion/72764/any-way-to-permanently-adjust-rigging-to-shape?utm_source=google&utm_medium=cpc&utm_campaign=&utm_content=&utm_term=&utm_matchtype=&utm_creative=&gclid=CjwKCAjwwo-WBhAMEiwAV4dybYwx9jbt8q8j3eOHgYxNRBTaO3GaSJFBZAyc_a4foKx9S8NE35unfRoCfzcQAvD_BwE Maybe I did something wrong when I orginally did erc freeze.
