DAZ3D Iray, MAC and CUDA
kaltlandkaltland Posts: 55
edited June 2015 in Daz Studio Discussion
Hi everyone,
I have an 2009 imac, dual core and I'm suffering while rendering IRAY, it takes much time so I decided its time to upgrade.
A very nice guy said a new imac 5k, comes with a good NVIDIA GeForce GT 750M 1GB, GDDR5. I'm wondering if DAZ3D would use GPU as an option, instead of CPU. And if my renders would be fast enough.
Maybe if I install a CUDA driver?
thank you!
Post edited by kaltland on
  • nickalamannickalaman Posts: 196
    Your guy might be nice, but he's a little confused. The 5K iMacs all have AMD video that are not compatible with iray. The non 5K iMac has nvidia with will work with iray.
  • Richard HaseltineRichard Haseltine Posts: 111,348
    The system is compatible with Iray, it just won't take advantage of the GPU.
  • kaltlandkaltland Posts: 55
    thank you.
    the question is
    would a intel i7 CPU be as fast as a Nvidia GT 550M GPU when rendering IRAY?
    Im deciding between a mac 4k (i7) without NVIDIA and a simple mac (i5) with Nvidia.
    so hard decision.
    thank you.
    the question is
    so hard decision.
    No...the CPU render will be slower than the GPU render, by a large margin...but, you will be able to render much larger scenes with CPU, than the GPU, because scene size is limited to the DEDICATED memory on the video card. If it doesn't fit, then it falls back to CPU rendering, so you would lose any speed advantage, anyway.
  • EsemwyEsemwy Posts: 578
    You might want to look into an old model (pre-trashcan) Mac Pro. You can still find them, and at quite reasonable prices (for a Mac). With that you can put whatever memory and disk is appropriate for your needs, and still use a modern Nvidia GPU. I installed a GT 980 in mine when DAZ introduced 4.8, and I've been quite happy with it. I got my card from MacVidCards.com. They reflash consumer PC cards with Mac firmware.
    thank u;-)
