Are there any sliders for the head morphs in giantology?
Al lI can find is the icons in library, nothing in parameters even after a head shape is applied and currectly used in sleceted
thanks
https://www.daz3d.com/giantology
  • Richard HaseltineRichard Haseltine Posts: 111,792
    It certainly includs asset files for the morphs, so there should be sliders somewhere on the figure.
  • VicSVicS Posts: 1,273
    I searched all over with both only head and also  full body selected so if anyone has used them and can help me know where that would be great-
    other thing is applying the face morph is making the arm skin all shriveld up so I'm wondering if there is a way to prevent that from happening as well
    thank you
    You are using them on Genesis?
  • NorthOf45NorthOf45 Posts: 5,915
    On Genesis you do not have to select the Head node to see which morphs are active on the head (unlike M4/V4). Select Genesis in the Scene tab or in the drop-down list in the Parameters tab, then Curently Used. Often the morph names have some key word in common with the product name, so try putting "Giant" in the fiter text box and see what comes up. Expand the list on the left to see where they are located in the parameter tree.
    My Giants don't shrivel, so there must be something else at play. Currently Used might show something (try showing Hidden Properties if nothing suspicious shows up).
    edited July 2022
    Ok all good now, the arms shrivel when giant body is applied on genesis, there are sliders for both body and face,
    putting "RAW" in the search brings up all the sliders-
    thank you
    Post edited by VicS on
