Fit To Problem
bryanll1bryanll1 Posts: 141
This may be a stupid question, but I'm new to this software and stupid.
I attempted to Fit a Victoria 6HD to the Cyclone Fighter, but the software attached her to the starboard gun. When I tried to fit the Cyclone Fighter to the Victoria 6HD, it crushed the fighter around her.
Am I doing something wrong here or is this an impossible task?
    You don't need to fit her to the fighter/fighter to her...
    Fit to is used for clothing/hair, mostly. And very rarely, if ever, for props/vehicles. There should be some included poses...for at least one figure. Even if they aren't for V6, they will work well enough to start with and may need some adjustments, but not as much as starting from scratch.
  • bryanll1bryanll1 Posts: 141
    I did the pose before the fit attempt. How do I lock the pilot in place after placement in the cockpit?
    Use Parent to instead of Fit...if you right click on V6, you should have a Change Parent option. Use that.
  • Richard HaseltineRichard Haseltine Posts: 111,093
    Parent the figure to the thing you want it to move with - at a guess the cockpit doesn't move separately from the rest of the ship and you'd parent to the hull bone, but that may not be the case.
