Render settings in DAZ3D
jaxtonejaxtone Posts: 73
First of all I must mention I never thought that a render engine could be as slow as DAZ3D´s in 2022.
But the main problem is that it seems impossible to raise the resolution in a spot render of a limited region of a model in DAZ3D. The render result will only come out as low resolution [thingy] even if I try a full size or limited render process.
If anyone of you have figured out how to solve this I will listen and learn.
  • LeanaLeana Posts: 13,499
    If you set the spot render tool to render to a new windows rather than to the viewport (in the tools settings tab) it should render it at the same size and resolution as that portion of image in the full render.
