Iray Viewport better then actual render?
vonHobovonHobo Posts: 1,715
edited June 2022 in The Commons
https://www.daz3d.com/roly-the-panda
I am working with this Roly the Panda character and the Iray Viewport preview looks amazing (first image attached).
But when I actually render the image, it looks weird, like the hair is whispy or almost not there (second image).
Why would the preview look better then the actual render?
990 x 990 - 2M
1200 x 1200 - 2M
Post edited by vonHobo on
  • GordigGordig Posts: 10,840
    Since you're working with dForce hair, it's most likely something like Render Line Tesselation being set too low.
  • vonHobovonHobo Posts: 1,715
    Thanks that fixed it. Changed it from 1 to 2.
    Strange that the viewport would use different settings than the render though.
    The viewport renderer is different from a full render, it's using Iray Interactive, which is different from the full Iray render.
    edited June 2022
    You have a choice of what mode to use in the Iray Preview in the viewport. You can choose Photoreal if you prefer. This is configured in the Draw Settings pane.
    Edit: I made a screenshot of the Draw Settings pane where this option can be found, but the stupid forum software will not attach it. There is a whole thread about the forum not uploading images. sad
    Post edited by barbult on
