How hard to manually apply textures and materials to organic model?
HorusRaHorusRa Posts: 1,665
edited March 2019 in New Users
Post edited by HorusRa on
  • Richard HaseltineRichard Haseltine Posts: 111,363
    You'd need to use the Surfaces pane, assuming the model was UV mapped. How hard it would be would depend on how many surfaces there were, how many different groups of surfaces using different maps there were, and what types of map (diffuse, bump, normal, specular, opacity....) there were and how clearly the maps were named. It could be quick and easy or protracted and tricky.
  • HorusRaHorusRa Posts: 1,665
    edited March 2019
    edited March 2019
    Sixus' stuff...yeah it works in DS...the tweaking isn't too bad.
    edited March 2019
    edited March 2019
    It would be an old-style figure, so use Save As > Deprecated > Materials Preset
    edited March 2019
    edited June 2015
    There's also a deprecated character preset...but with the old/Poser stuff I usually find it easier to make a materials preset, if it's just a texture.
    You can also use the Scene Subset save...that will merge a textured, posed, clothed and whatever else item or bunch of items (props, characters, etc) into an existing scene.
    Post edited by mjc1016 on
    edited March 2019
    You may need to use the 'eye' to make them invisible, instead of actually removing them.
    It may be that that is a Poser-only feature - in Poser there's a Genitalia switch in the Figure menu that will load an alternative hip geometry and there's certainly a NoGen OBJ file listed in the readme. Try selecting the hip, possibly enabling Show Hidden Parameters in the Parametrs pane option menu, and seeing if there's an option to switch geometry - probably a list button with two entries.
    Ok...found it for one other Sixus figure. Most vendors stick with similar methods when they have something that works...
    There are two parameter switches....one is under the hip and it isn't listed in the morphs, but rather General > Misc > Switch Hip. Then the same under Genitals. You need to use both.
    edited March 2019
    edited March 2019
    TY
